TwinTurbo.NET: Nissan 300ZX forum - flow test between stock, modified, z1 and 60mm FTW! (n/m)
BoneZ (MD)
on November 18, 2011 at 12:35 PM
I don't know that it's possible. That's why I said if you
posted by Wright (Ca)
on November 18, 2011 at 10:45 AM
Fun with the CNC lathe
Rob'Z
18:09:04 11/17/11
I hope you do this and keep it affordable (n/m)
ztunerz
18:27:17 11/17/11
Is there a way that you can verify that the plates seal up
Wright (Ca)
18:33:26 11/17/11
Could you also please include milling off the casting
JMartz
18:36:21 11/17/11
I could probably do that
Rob'Z
21:32:30 11/17/11
After looking more closely
Rob'Z
18:39:30 11/18/11
you can also mill down the throttle shaft and plate screws
Dane (Houston)
19:46:47 11/17/11
That is the next step. (n/m)
Rob'Z
21:30:52 11/17/11
Estimate on price? (n/m)
new2boost
22:18:16 11/17/11
I was thinking
Rob'Z
22:45:41 11/17/11
Id be down for a "group buy" modification.
new2boost
11:41:43 11/18/11
i have a few sets of TBs ready. flow numbers would help
ztunerz
12:34:35 11/18/11
Looks like I'm not charging enough.......
Rob'Z
22:53:30 11/18/11
I'll pay that right f'n now.
Jehannum
20:47:40 11/22/11
How thin is the forward facing barrel? (n/m)
thumper
00:00:32 11/18/11
Yeah, is it T-Bolt safe? (n/m)
MPV TT
00:41:30 11/18/11
My question exactly
BlackholeZ
02:24:13 11/18/11
The problem there is that you can't use stock or
Rob'Z
09:37:12 11/18/11
I think you would have quite a few buyers interested if you
Wright (Ca)
10:25:45 11/18/11
How would you do that and not have it taper down anyway?
dogpile
10:36:27 11/18/11
Wright (Ca)
10:45:25 11/18/11
Gotcha. Thought you had an idea in mind that I wasn't seeing (n/m)
dogpile
10:51:04 11/18/11
flow test between stock, modified, z1 and 60mm FTW! (n/m) -
BoneZ (MD)
12:35:35 11/18/11
Re: I think you would have quite a few buyers interested if you
Rob'Z
12:39:50 11/18/11
If that $400 is for the pair, that's not too far off from
dogpile
13:17:05 11/18/11
Well I can't do it for less....
Rob'Z
18:53:50 11/18/11
correct. (n/m)
ConVerTT
18:57:46 11/18/11
I agree
dogpile
18:58:28 11/18/11
Thank you
Rob'Z
19:27:52 11/18/11
Nope, just poor word choice on my part. Sorry about that (n/m)
dogpile
19:42:03 11/18/11
Do it! I want a set now! (n/m)
Evan(CA)
20:30:14 11/18/11
I'll order the billet on Monday
Rob'Z
21:06:56 11/18/11
Reverse taper using 2.5" couplers. (n/m)
Evan(CA)
21:22:56 11/18/11
Now you're talking!
BoneZ (MD)
14:19:14 11/18/11
Is ther a 60mm Tb that bolts up to the Z32 plenum?
Rob'Z
17:53:14 11/18/11
Links inside. What would you do for the shaft?
BoneZ (MD)
19:22:58 11/18/11
Rob'Z
19:58:12 11/18/11
Current 60mm+ TBs do not bolt up, they require plenum or TB
induetime
21:42:13 11/18/11
The problem with the barrel method is
Rob'Z
18:55:11 11/18/11
Good points Rob
BlackholeZ
19:02:44 11/18/11
On the 65mm TB needing a tapered coupling
Rob'Z
19:24:15 11/18/11
Why not do some testing and verify just how strong it
zellamay
11:30:54 11/18/11
It's almost a knife edge at the leading edge
Rob'Z
19:22:09 11/18/11
How big is the stock bore on OEM TB's? (n/m)
ZXoltan
02:49:24 11/18/11
50mm (n/m)
aliaZ
07:11:35 11/18/11
Do want. (n/m)
08:55:33 11/18/11
Pics of the modified shaft
Rob'Z
17:56:42 11/18/11
Very nice! Keep up the good work!
sak01
19:09:13 11/18/11
Re: Pics of the modified shaft
supergoji
10:31:16 11/22/11
Dimensions make it seem barely any upgrade. Hopefully flow
RevTech
19:33:46 11/18/11
